runs between batteries?
darren700
got bu/\/\p?
i am going to be running two kinetik hc2400's in the trunk of my car. i have 4 1/0 runs to the back of my car (2 positive, 2 negative) the batteries must be on oposite sides of the trunk. i plan on connecting the runs from the front and the amps to the battery on the right of the trunk. my question is how many runs of 1/0 should i use to connect the battery on the left to the circuit? should i use two runs of positve and two runs of negative? or would i be alright with just 1 run of each connected to that battery? thanks
I have a similar setup. If i was in your shoes, I would run front batt +and - to rear right battery. Front batt+and- to rear left battery. Connect right and left rear +and -. If you do wire it as you have described, yes, I would use two runs of pos and neg however this seems a bit excessive. One run of 1/0 to the batteries should be just fine.
most important thing is that your current has equal amounts of resistance in the circuit.
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
funkyab
