running two different sets of mids with a component set
darren700
got bu/\/\p?
ok, i bought a set of mixed cdt hd-62 components, (his hd mids were stolen)
it has the drt-25 tweeters, 560 crossovers, and ascendant audio 6.5" poly midranges.
i originally planned on replacing the aa mids with cdt m6's mids. but now i have another idea.
could i run the set of compents with the aa mids hooked up to the 560 x-over on two channels of my amp, then run a pair of m6's sealed in kicks off of the other two channels, using the amp to bandpass the m6 mids? i planned on using the US Amps XT-1600.4 (200watts rms x 4 @4ohms) for power. if i used this setup would i run into problems with cancellation because the two pairs of mids are perpendicular to eachother? thanks for any help
Why?
If anything, I'd run the AA's as dedicated midbass... in a properly deadened door. Then run a set of mids as midrange.
You'd want to properly cross everything over. Basically, without a full active xover, and amplifier capable of of bandpassing over a wide range of frequencies... it's not worth it... and kind of difficult.
The answer to your DIRECT question... of running both of them... on the same frequencies... that would sound horrible.
nG
Why?
nG
im just wondering if i should be happy with the aa mids when they come, or should i upgrade to m6's?
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
ngsm13
