Running speaker wire with power wire
  • 5
BassHead50008
Is there anything wrong with running speaker wire down the same side as your power wire? The guy at a local audio shop ran the rca, amp wire and power wire down the side of the car. I was told a long time ago that the power wires are suppose to be on one side and every other wire ran on the other side or it will create a bussing noise in your system speakers. Fact or myth? Tips anyone?
I ran mines on opposite sides. Why take a chance that there may be interference. When I installed mines, the general consensus was to run them on opposite sides. Maybe your installer has had a good experiences with the wire that he uses. Personally, I would avoid any future problems by running the wires opposite each other.
I run RCA’s and remote wire on one side and power wire on the other. I do try to run my speaker wire with the RCA’s though. If there’s no interference then I guess no worries?
It may or may not cause issues. It is common practice to keep RCA away from power wires or cross them at 90 degree angle if they have to cross each other to avoid potential induced noise.
That really depends on your pre-out voltage for the head unit. Above 4V and it doesn't matter too much until you get into big big power. 5V you'd be good almost no matter what.
That all being said it's true that it's good practice to separate them and not doing so could mean a lot of headache later. RCAs should usually go down the same side of the car as your antenna signal and then the power cables should go in the opposite side. RCAs may not mind too much (with a quality source signal) but your radio does.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
384
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
BassHead50008
BassHead50008
California
Lasherž
SlugButter
    May 4, 2024
slater
    May 2, 2024
