running power wire in 94 camry
There should be a grommet down behind the gas and brake peddle. This is where other wires from the engine area enter the interior compartment. It's usually a piece of rubber with a hole in the middle that wires going through. Try to squeeze the power wire through it.
I have a 98 camry and there is a hole in the firewall behind the front driver side wheel well. A friend of mine has a Scion(toyota made) and there way also a hole in the firewall there also so it might be a common place toyota uses. Not sure if that will be the same since you have a 94 but check to see if there are wires that run down and just disappear down there. If so your going to have to remove the wheel and get into the wheel well. Be prepared to destroy a bunch of plastic clips.
thanks, i already got it firgured out, there wass a plug on the passenger side, the plug was up pretty high
had to ttake the lower part of the dash off the get to the power wire, had to cut some insalation but walla , with an extra set of hands feeding it through we got it
GTonDubs
GTonDubs
mo
GTonDubs
michigan born
    May 14, 2026
michigan born
    May 14, 2026
