running half ohm
i got my deka intmidator g31 for only 115 at the factory cause it had a blemish. look around theres plenty of good batts
well i ended up getting the sub but i dont know what ohms the coils are when i measured them at the dudes house it was a lil under 2 on the voltmeter both coils
ok but he said when he hooked it up to 1 ohm off the diagrams on 12volt his amp would cut off he had the hifonics 2000 watt amp so idk unless he just a artart
electrical and fuse size is the problem..i just sold a dual 1 18"fi bl and had a alphasonik pma1000hca to it..decided one day to wire in parallel down to .05 ohm and it played until i got volume past ten than it blew every fuse i had on the power wire..so make sure u do the big 3,extra batt,atleast 150 amp fuses and alot of prayer..sell it and buy a dual 2 than u can go to 1 ohm..i bought a dual 2 18"btl old 3 stack motor and installed today down to 1 ohm and it hitz harder than i ever heard..
jstinbc
jstinbc
Cville, MI
dirtysouth31
