running active with horns, cd8445 headunit good for running active?
would a zapco SLX4 work for the active crossovers?
Features
Simbilink Balanced 4-Way Crossover with Separate Inputs
- 6 Way 4 Output Variable Crossover
- SymbiLink balanced inputs and outputs.
- Individual variable crossover points.
- Dual input capability.
- Slave outputs for easy system expansion.
- 12/24dB per octave options for low pass.
- No external power wiring necessary when used with
SymbiLink amplifier.
- High signal voltage capability.
- LED clipping indicator.
- Dashboard or trunk mountable.
- Gold plated signal connectors.
Specificatons
Max Output Level:
- Balanced: 15 volts
- Unbalanced: 7.5 volts
Input Impedence: 4.75k ohms
Output Impedence: 680 ohms
Separate Inputs for Front, Rear and Sub
THD + Noise:
S/N Ratio: >105dB
Stereo Separation: >80dB
Dimensions: 3.75"D x 6.25"W x 0.95"H
that crossover should work. but a little excessive for your application because that is a 4 way crossover. i'm guessing you are going with a 2 way frontstage so you dont need a 3 way setup for your frontstage.
thadman
thadman
Indiana
thadman
