running active w/ cd2 horns, what mids?
thadman
I planning on purchasing a set of image dynamics CD2 comp horns and an Eclipse cd8445 ($300 shipped buy-it-now brand new on eBay)
I have roughly ~170-200 watts @ 2ohms for the mids from a DLS A5 amplifier, would the new Dayton RS 4ohm work well with horns?
Would ~60 watts for each horn be enough? (looking for a DLS A1 amp for the horns)
Is the cd8445 a capable enough headunit to run active?
Perfect for XXX6.5's
I just recently installed some of the custom VifaXT25 tweeters from ascendant, and I was able to crossover my mids lower (around 1.2-1.6kHz haven't decided where to keep it yet)... and the sound is AMAZING.
It took A LOT of stress off the mids which I used to have do all the way up the 2kHz... they sound clean, accurate, and have great output. By just installing the tweeters, I love the whole setup even more.
So, since the CD2 horns are able to go down reasonably low, I suggest the XXX6.5's to mate with them. Also, the power @2ohms will be perfect.
NG
Ive read several reviews that the XXX mids have incredibly poor performance and arent very good SQ drivers (get loud tho)
I'd like ologys mids, but I have no idea when or if theyre even coming out soon.
would the internal amp in the cd8445 be enough to run horns? It says 4 x 50 watts max...which I highly doubt they put out that, but does it have enough juice to run at least 2 x 16 watts rms?
I knew this was coming. Those reviews are bullshit, period. I challenge ANYBODY to hear my setup...then they'd change their mind.
Seriously, a newly found audio friend of mind... who is hardcore into Home Audio SQ...owns ~$4k pair of stereo mains... loves the current front stage setup. I told him to be blatantly honest with me. He's seen the reviews and thinks it's bull as well.
I dunno, I just think it's bullshit for people to judge without hearing them. BTW mine are in sealed door pods, in ~.2-.25 cubes, with around 200rms per side.
NG
What other options do I have (keeping my horizons open), I'll keep the XXXs in mind. I'd like to stay right around ~100-120$ for both of the mids.
Once again Could I use the cd8445s internal amp for now to power the horns (until I get a DLS A1)
what size would mate best with the horns? If I got 2 I could run them the amp at 2ohm correct? Which would give them each above their RMS. If I ran 2 8s per door with their rated power, I'd be looking at 98dB correct?
midbass
92+6dB (running additional driver with RMS to each driver)
with 170 watts to each door id be looking at
98 @ 1
101 @ 2
104 @ 4
107 @ 8
110 @ 16
113 @ 32
116 @ 64
119 @ 128
170/128= 33% increase, 3dB(.33)=
120dB @ 170 watts @ 2ohms
so I should see about ~120 dB rms correct?
horns
109 @ 1
112 @ 2
115 @ 4
118 @ 16
120dB @ 27.5 watts @ 8ohms
27.5/16= ~66% increase, 3dB(.66)=
27-28 watts per horn would balance with the 2 8s, theoretically?
thadman
thadman
Indiana
thadman
