Running a system off a stock HU...help
if you don't want to use the jl cleansweep or the rockford piece, i would at least recommend an audiocontro LC6. it's cheaper than the other options, and if the processing is in the amp and not the head (which should be correct) then you won't have any HUGE eq curves to have to overcome. the LC6 will give you a clean, STRONG pre-amp signal to feed your amplifier(s). most systems i've done with an LC6 sound every bit as good as similar systems i've done with aftermarket decks, plus you retain the looks and features of your oem headunit. you can hide the amp, and your other components and nobody will ever know you've upgraded anything at all //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
williams22
williams22
Vermont
thefunkybunch
