Running 16 gauge between amp and sub?
Coltsrock
found a 1/0 wiring kit that includes: 17' 0 Gauge Translucent Red Primary Wire
3' 0 Gauge Translucent Brown Ground Wire
17' Twisted Pair RCA Interconnects
16' Blue Remote Turn-On Wire
20' Translucent Black 16 Gauge Speaker Wire
Positive Battery Terminal
Genuine ANL Fuse Holder
150 Amp ANL Fuse
3 Gold Plated 0 Gauge Ring Terminals (Red)
3 Gold Plated 0 Gauge Ring Terminal (Black)
2 - 16 Gauge Butt Splice
10 - 4" Cable Ties
Split Loom Tubing
will the 16 gauge be fine running between the amp and sub or will i need some higher gauge wire for that?? I figured this kit is great because its only $40
and I'll pushing around 1K watts to a single 10" if that helps
ahh well i can get some 10 AWg for .60 a foot, so i'll just pick up like 5 feet of that stuff and call it good, since even with 10AWG, it'll be the cheapest 1/0 kit i've seen
yeah for 1kw you prob want 10 gauge going to the sub
alright thats cool, even if i order 5 feet of 10 AWG, it costs $43, which is great for a 1/0 kit and 10 awg going to the sub //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what brand is it? some 1/0 wire is more like 4ga with a shitload of casing.
1/0 Gauge 4000 Watt Amp Amplifier Wiring Kit 0 GA SQK0 - eBay (item 180531152871 end time Sep-07-10 15:18:56 PDT)
can't really tell :/
EDIT: SoundQuest is made by stinger, and they make good wire right?
Coltsrock
Coltsrock
Omaha,NE
Coltsrock
