run amp power in 92 maxima
jcampisi
I have a 92 nissan maxima and i need help running my power wire for my amp through the firewall. Is there a pre exsisting hole i can run through or do i need to drill? if I need to drill hole any suggestions where a good location would be so not to drill through something important.
thank you
Depends on the wire size. I had 8 AWG running to my last amp. There is a small rubber gasket on the passenger side with a hard line going through it. You can poke a hole and run your wire through there if it's 8 AWG or smaller.
Anything bigger and you will have to drill a hole. I am going to be doing the same in my Maxima with 1\0 as soon as I can make the time.
jcampisi
jcampisi
roseville,ca
PR1M3R
