Rule Interpretation
So...if I do decided to build a wall...would I be in streetmax 1-2 or superstreet 1-2? I have to remove the rear seats. I am not sure if that is considered a body modification or not. 2 subs, 2 amps, 1 battery unless I am in super street 1-2, then I will get another.
SM 1-2 only requires ZERO MODS in front of the B-Pilalr.
2 subs, any size.
upto 4 amps but only 4 condutors (wires).
1 battery.
You do NOT want to get into SS1-2 with a DD car.
But what about behind the B pillar, ie removing the rear seat to build a wall? The pics on termpro looked liked they removed seats to build a wall.
When it says 4 conductors, would this be legit:...2 runs of 0 ga from battery (under hood) One run of 0 ga to each amp, each amp would have 0 ga ground. 4 connectors right? I would just have to disconnect amp running mids/ highs when I competed, correct?
Looks like SM1-2 may be class for me once I understand the rules. I have read them, just not understand them.
What part of "SM 1-2 only requires ZERO MODS in front of the B-Pilalr" doesnt make sense?
By conductors the rules mean Speaker wire. You can literally have as many power wires from the battery as You like (so long as no other rule is violated). But You can only have (4) wires runing between the amp(s) and the enclosure.
So (2) neg., (2) pos..
I see....so running DVC is okay as long as 4 total wires lead from amp to enclosure (2 amps at wire wires each is good)
...You didn't have to type all large like that. A mere "that is correct" would have sufficed. Either way, I am thankful for your help.
DVC is fine but QVC is a no-no.
upto 4 total wires between the amp & enclosure.
Yea, You're welcome.
Flipx99
Violator of Terms
Flipx99
Building 100
Nikuk
