Rule Interpretation
does it have to be a 12v battery?
6-7i Competitors in the Street A and Street B classes are limited to 1 battery. Competitors in the Street C class are limited to 2 batteries.
Additional Guidelines:
· Aftermarket batteries are acceptable.
· Batteries must be of the 12-volt variety.
· Hybrid (ie 12/16 volt) and/or custom-made batteries are prohibited.
· The physical size of each battery is limited to 800 cubic inches (13110 cubic cm) or less. (Height x Length x Width. Excluding the battery terminals.)
· The primary battery must be located in the stock OEM location. The secondary battery (if installed) may be mounted wherever the competitor desires behind the B-Pillars or under the hood provided no other applicable rules are violated.
· Batteries may not be mounted underneath the vehicle. (Underbody battery boxes, racks, etc. are prohibited.)
· Batteries may not be swapped out during the course of an event.
thanks, thinking of trying drag next year and im running a 16v for my meca setup just wanted to know if i could do the same for drag.
I wonder how much is the competition difference between streetb and streetmax1-2.
I was thinking of buying another merlin d2 and then buy 2 juggernaut 12's. (since the RMS match pretty good at 1500 watts) I could disconnect the diamond audio and then I would be set.
still questing for 150
I wonder how much is the competition difference between streetb and streetmax1-2.I was thinking of buying another merlin d2 and then buy 2 juggernaut 12's. (since the RMS match pretty good at 1500 watts) I could disconnect the diamond audio and then I would be set.
street b was won with a 53 or something, streetmax was a 61 even iirc...someone broke a 60 in street c at euro finals //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
well, atleast I got my work cut out for me...Now what I am curious is how much of the available trunk space is occupied by the box affects SPL.
Might get a friend and me to go in on a termlab. Is the laptop necessary or does that screen come with it?
test, test, test. Ony way to go.
Oh, and the 1st thing You buy is Your own TL.
The second is a Batt. Charger.
Post up on here or at Termpro for advice, help, tips.
Flipx99
Violator of Terms
Flipx99
Building 100
Nikuk
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
