RP1500.1D cuts out
  • 4
Skared94Camry
ZVX-15v2 dual voice coil 1 ohm, with rp1500.1d have it wired parallel, was hitting hard now my amp seems to lose power after about 5 or 6 mins of playtime with bass boost turned all the way down. It starts working when I pull inline fuse and reinsert, android head unit, I'm at a loss, even wired in series, seems to have performed even worse
The losing power after 5-6 mins seems like you are dropping battery voltage and losing power from that. The fuse thing doesn't really make sense to me though. Wiring in series would give you drastically less power since you would be going from 1 ohm to 4.
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
287
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
Skared94Camry
Skared94Camry
Carolinas
Jeffdachef
    May 19, 2024
    May 19, 2024
