how much wood working you planning to do?thank's then think i may look at making a router table
I agree.It would be easier to just router the edges with a router. If you try to use a table, you will have to lug the big box up on the table to do it. Just easier to do it by hand.
True, forgot about this.You can set depth with a non-plunge router, too, but anyway.
If you're going to do a double roundover with a 3/8" bit, you'll need a table. You have to run the wood vertically through the bit for the second cut because the first cut removed the material that the bearing would ride on for the second. I do most of my round over work before box assembly.
