Rookie here..need some help
boomchee
Hey Everyone,
I have a sony gtx-100 hu, an rf r500-1 amp and an rf p2d212. It hits pretty decent but it seems as if I should be able to get more out of the set-up. Any suggestions would be appreciated..oh it's in a 93 deville (huge 3 body trunk)
2 ohms..Funny you mention the BIG 3, I got this amp Saturday and by Sat night my alt went bad (250 for alt and itstall)..I had it wired by a shop and I beleive 8gauge wires were used, need to double check though..The interior speakers..Dash Sony X-plod 4x6 4way rear deck Sony X-Plod 6x9 4 way still have the stock 5 1/2's in front doors.
You should use at least 4 guage for power, and also you cannot have a 2 ohm load with a Dual 2 Ohm sub.
Enclosure---Ported looks to be about 1.75cu ft...2.5 inch port top tyo bottom. Box is fatter at bottom than top.
it'll probably sound much better if you make a box.
and its a hatch box, the port is ****ed up because you cant have a slanted back with an L port, unless its just not tuned to anything....
What's an alternative? I like the sub/amp but I dont want to damage anything. What could happen if I continue like this?
it'll probably sound much better if you make a box.and its a hatch box, the port is ****ed up because you cant have a slanted back with an L port, unless its just not tuned to anything....
I believe I have a regular box somewhere at home. So that in itself would improve the sound somewhat?
making a custom box would be best, but i think you have a hatchback box (back is slanted so the base is wider than the top) which i dont know how they would do the L port.
Im pretty new to all this stuff too, but just lurking on here has helped me alot.
Regular as in sealed? or regular as in a cube box?
because I guarantee that a custom box will be better.
boomchee
boomchee
pgh-pa
sacsking916
BP1Fanatic
BP1Fanatic
