Rockfordfosgate 1000w Mono Chann
meaneemeeh
has any tried running this mono chan amp on two JL audio 12" w3v3?
think it should be efficient enough to run them both?
Rockford Fosgate Punch 1000W Class BD Mono Amplifier with Variable Crossover
1000W peak output @ 2 ohms
750W peak output @ 4 ohms
500W RMS (continuous) @ 2 ohms
250W RMS (continuous) @ 4 ohms
Variable LP 40-250Hz crossover
Dynamic thermal management prevents overheating
Bass boost; on-board Punch EQ
4-gauge power and ground input
the JL Audio w3v3
SPECS:
Nominal Diameter: 12 inches
Continuous Power Handling: 300 Watts
Coil Resistance: 4 ohm
Xmax (one-way, linear): 0.550 in. / 14.0 mm
Driver Displacement: 0.049 cu. ft. / 1.39 liters
DC Resistance: 7.240 ohm
Efficiency (1W/1m): 85.22 dB SPL
Mount Depth: 5.93 in. / 151 mm
has any tried running this mono chan amp on two JL audio 12" w3v3?think it should be efficient enough to run them both?
the JL Audio w3v3
SPECS:
no.......no.......no!!!you will blow the hell out of those jl's rockford amps are under rated
meaneemeeh
meaneemeeh
Union City
mixtapekid
