XXV Amps RMS Power
Team Maxxsonics
Ok, we have read a lot of posts regarding power at differant voltage and loads so here is the straight scoop.
These numbers are rounded down to closest 100 (not rounded up)
Some in-vehicle testing has resulted in higher power but this should help.
I know your next question will be how much so for that, if you are a competitor and have a stats page, you will have to call Mike Stiers at (847) 540-7700 or e-mail mikes@maxxsonics.com
Mono amps (......1-Ohm.........)
Model 14.4v 16v 17.8v
XXVThor 3000 4000 5000
XXVCyclops 4000 5100 6300
XXXGoliath 5000 6300 7600
XXVSampson 8000 8900 10,200
XXVMaxximus
2 Channel / Dual Mono Block amps
XXVColossus
14v: 2 x 1600 @ 1-Ohm / 1 x 3200 @ 2-Ohms
16v: 2 x 1900 @ 1-Ohm / 1 x 3800 @ 2-Ohms
XXMaxximus
14v: 2 x 5000 @ 1-Ohm / 1 x 10,000 @ 2-Ohms
16v: 2 x 6300 @ 1-Ohm / 1 x 12,600 @ 2-Ohms
17.8v: 2 x 7600 @ 1-Ohm/1 x 15,200 @ 2-Ohms
my problems with them is they are so inefficient...but they are cheap //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Uhhhh not correct.
These are probably (and likely) the most efficient amps you can buy.
These are atleast 13-18% more efficient then the XX series.
They are perfect for street all the way through extreme.
You need to check out termpro and see the competitors that are using them in competition.
They're putting up huge numbers on a single bat and very little voltage drop.
Team Maxxsonics
Team Maxxsonics
Chicago
Team Maxxsonics
