Rockford Fosgate Punch P400-4 4 Channel Amplifier
  • 1
turtlestrap
Oregon
Rated Power
(RMS Continuous Power):
50 Watts x 4 @ 4-Ohm
100 Watts x 4 @ 2-Ohm
200 Watts x 2 @ 4-Ohm Bridged
Condition of amp:
Cosmetic: 6/10
Function: 10? 9? 8? 7? /10
Got this from a friend of a friend. Pictures show cosmetic condition of amp, which isn't that great, but overall not too bad, especially if you're not going to install it in the open.
Took it to the local car audio shop today to have them bench the amp and it powers on no problem and plays on all four channels.
If you look closely at the pictures you can see that the left channel RCA's are slightly bent. The guy that benched the amp told me that while it does play from all 4 channels, since the left RCA's are bent, there is a chance of hearing engine whine through the speakers. The RCA connections aren't loose or anything, just slightly bent, as shown in the pictures.
The friend of a friend said it worked perfectly fine and had no issues with the amp though.
Would metal wire wrapped around the RCA connectors similar to how people wrap them on the back of some Pioneer HUs solve whine if there was any?
Other than that, no other functionality issues, just cosmetic as shown in the pictures below
It is probably 100% functional with no engine noise or anything or easily fixable with grounding loop for RCA's.
$100 Shipped within lower 48 states
Shipping is on me.
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
turtlestrap
turtlestrap
Oregon
turtlestrap
    May 18, 2024
    May 18, 2024
