Rockford Fosgate PRIME R1000-1D
trenthonda1
Florida
Fosgate Prime 1000 mono amp
Amp works perfect! 9/10 cosmetic condition 10/10 working condition
The amp has never run hot or over heated. I purchased it new
PRIME Series Single-Channel Monoblock Class D Car Amplifier
RMS power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Variable Bass Boost (0-12 dB bass boost at 45 Hz)
Single-channel operation
Wired remote bass level control included
Preamp rca outputs to daisy chain multiple amps
Heavy duty extruded aluminum alloy heatsink for optimal heat dissipation
Dual speaker terminals simplify the hookup of multiple speakers
Nickel-plated rca level inputs
Nickel-plated screw terminals
Input sensitivity:
Level: 150mV-8V
Variable low-pass filter (40-130 Hz, 12 dB/octave Butterworth)
Damping factor: >200
Phase Shift: 0-180°
CEA-2006 compliant amplifier
Frequency response: 20-130 Hz
Dimensions: 7-11/16"L x 12-1/8"W x 2-7/16"H
180 shipped obo
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
trenthonda1
trenthonda1
Florida
alec14
    May 20, 2024
    May 20, 2024
