What sub and amp? It all depends on the impedance of the sub and what the amp will put out at that impedance.Originally posted by HONDAPOWA I was just wondering. is it ok for a sub rated with 300rms to be powered by a 600rms amplifier? Are there any potential danger of damaging the sub? just wonderin. thanks
what amp? And what subs, DVC 2 or 4 ohm?Originally posted by HONDAPOWA the alpine type-r 12"?
Wire the subs to 2 ohms, they'll get 300 watts eachOriginally posted by HONDAPOWA ok the subs are dvc 2 ohm, and the amp is the JBL BP600
You have 2 of them, correct? If you wire them to 2 ohms, they will each get 300 watts, which is their RMSOriginally posted by HONDAPOWA the box? ahg. any box that works. and uhm.. 100watts? wouldnt it be like, 300 watts more than it can handle? since its rms rating is at 300 watts.
If you have one, wire it in series for a 4 ohm load, itll get 300 wattsOriginally posted by HONDAPOWA but what if i have one?! AHg. if i set it as a series instead of parallel, would it fix it?
Yea your good to go!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifOriginally posted by HONDAPOWA but what if i have one?! AHg. if i set it as a series instead of parallel, would it fix it?
