RMS Question
I just read on the sub again, and from what I understand it is dual 2ohm not dual 4 ohm. Also in requires more power than you are going to give it. If it is dual 2ohm you need and amp that is either 1ohm or 4ohm stable, the amp you want is 4ohm but only 400 watts. If you do get it you might want to go back with the A8002T which will give you 800 watts at 4ohms bridged. Good luck
K I will let you know, I probably wont get it until after the new years, so still gotta a week or so to figure everything out
DubbDesigns
DubbDesigns
KY
DubbDesigns
