rms and peak power
RMS and Peak are just manufacturers guidelines.
When referring to speakers/subs. You want an amplifier that matches the RMS of the speaker because that is what you will play at daily.
When referring to amplifiers, you want to match their RMS to the speakers RMS.
Peaks happen at different parts of different songs, or electrical peaks.
Match the RMS's up, and you should be safe. You can never hurt a speaker due to underpowering them, but you can hurt them by underpowering them, and cranking your deck to compensate, creating a clipped signal to the speakers.
Peak power is completely random in most cases. Some companies do 2x rms, some 3x rms...some 10x rms even. It's all a gimmick, don't count on it, and look only at rms values on good equipment because lower level companies like Pyle, Legacy, etc will just flat out lie about the rms values of their amps.
hmm... think I'm going to rewire my subs to 1ohm after reading this //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And as long s you know what you're doing, none of it really matters. The chances of you actually getting the RMS power out of an amp with music are somewhere around zero if the amp is set up correctly.
//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif, but 99% of people dont understand that
So called RMS power is the DC equivalent in terms of heating ability.. its the average amount of power the amp can deliver... peak power is the maximum instantaneous level...
There are various methodologies manufacturers can use to rate amplifier output, and the results can vary wildly... continuous RMS output over the intended bandwidth of the amp is the best kind of rating IMHO.. others will rate using 1khz, tone bursts, pink noise, ect...
leadparrot
leadparrot
maple shade, nj
helotaxi
