RL-s Vs. TC-3000
on the soundsplinter website they say that it really only needs 6 cubes sealed to do the trick and they also say that you could go ported 3 cubes but with extremely low tuning like 19hz why is that.
mrray13 put 1 in 2.5cubes tuned to 28hz and slap an orion 2500 on it(at 3.5 ohms he was getting around 1300 give or take) on a stock trailblazer hu...he was able to pop 140 @34 hz...so to me thats pretty good for 1 12
80
for the record its not a 4ohm coil its a 3.5ohm coil mike will even tell u that
It seems to be just a genuinely poorly designed sub
It requires a massive box for flat output...
has a 4ohm SVC
and a Fs that is way too high to be a HT sub
what the hell was this designed for?
has a 4ohm SVC
IB home theatre //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Still needs a ton of power and a ton of EQing...I'd rather get a couple other drivers and get the same amount of displacement for cheaper //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
We can make duals. The 5400 is D2 and the 4k will have a D1.5 option later on.
How much later we talkin??? Thinking bout either picking up 2 4kv2 or even a 4.1k, which ever you can get to me first! //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
D1,5 would be WAY better then that single 3ohm now
JimJ is always wanting "cheaper" //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
If people want to waste their money, might as well give it to me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
baseballfan698
baseballfan698
Indiana
JimJ
