Ring Terminals
k so basically take the point of the screw driver, and pound it into the terminal onto the wire.
is it necessary to shrink heat wrap the wire? or it just makes it look a bit cleaner?
i always start with pliers. then a hammer to get it nice and snug. you can use heat shrink or electrical tape with the rubber boot over than. if you don't have the rubber boot then heat shrink will of course look better.
Just smash it with a hammer, than take a screwdriver and use that to punch an indention in the terminal to help hold the wire more.
If you have heat shrink it helps make it look nicer, or electrical tape
Ellsworthz
98' firebird, sleeper ftw
Ellsworthz
Decatur, Indiana
brian84corvette
