Right Enclosure?
wangchung4541
I just got myself a pair of 2 Ohm 12" Alpine Type R's. I realized my box is a ported 3.47 ft^3 enclosure. I listen to rap, reggae, and operas. How do you think this will sound? //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
i bought it on ebay. check it out.
Features:
Built with 3/4" MDF.
3.47 cu. ft. total
Slot port ventilation system (see above description)
Dimensions: 32" width x 14.25" height X 16.25" depth
Two high quality terminals
HIGH SPL BASS SYSTEM
Two 12" speaker holes - fine cut
Sealed with several different non-toxic, EPA approved sealers (glue, staples, and hard silicone -- NOT cheap window caulking like our competitors) to ensure that the box stays together and make sure air does not leak.
High quality carpeting (charcoal colored).
There it is. What do you guys think? Two Alpine 2 Ohm Type R's
will i be fuct?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif :crap: //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Sub Sonic Filter. In a ported box, frequencies below the tuning will mess the sub up. A sub sonic filter stops these low frequencies from playing. In your case, u bought a prefab box which says "High SPL Bass SYSTEM" which most likely means it is tuned to about 45hz. Alot of music will go below 45 hz. So yes you will be fuct pretty easily with out a ssf.
But in my oppinion, I would try to sell this box that you bought and build your own. Or pay someone to build you one. At least 4.4 cubes before displacement and tuned to about 29-34hz.
I would also suggest you speak with Spkrman.
wangchung4541
wangchung4541
Boston, MA
JoseMCeee
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
