RF Punch 800a2 and 400.4 w/bridge and end caps
  • 1
Caraudiopro1984
I've got a set of Rockford Fosgate Punch amps, 800a4 and 400.4 with the bridge and end caps. Both work as they should. The 4ch has all the crossover chips and the cover. I can Skype, FaceTime or send video of them working before any transaction. I have good feedback on iTrader.
$500 shipped (lower 48)
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
767
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
950
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Caraudiopro1984
Caraudiopro1984
Vancouver, WA
Caraudiopro1984
    May 18, 2024
    May 18, 2024
