RF power Hx2 15" ported box help
  • 2
So I just picked up a power Hx2 15" for $50 I want to put it in around 2.0 or 2.5^3ft tuned to between 33 to 35hz. It is going in a civic so limited space can be about 32w x 16 1/4h x17 1/2d I don't know how long I'm going to keep it (getting a new 12 soon) so I was thinking about just doing a box with a tube style port if it is easier any help on design would be much apriciate. Btw it wi be running on 600watts for the time being
If you build it to those maximum dimensions, a 6" port 14" in length will give you a tuning of about 33-34hz, and around 3.6-3.7 cubes net which would be much more suitable for a 15" Power HX2, especially since you only have 600w for it.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
273
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
592
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
435
Quinn88
Quinn88
Eugene, Oregon
Quinn88
    May 20, 2024
    May 20, 2024
