Rewired Subs and Now i Smell Burning
abqsean
Hey folks, first time poster here. I had my box sitting in my garage for the last year but with the nicer weather i decided to put it back in my ride. I have a RF p5002 amp and 2 RF 12" p2 subs. When i put the box back in and connected the leads, i got no audio. The amp indicated it was outputting a signal so i got some new 12 guage wire and rewired the connection to the subs. Before, the signal looked to be bridged (i didn't set it up initially). When i rewired it, i put each speaker on its own channel (L/R).
It worked however i can smell a burning plastic/rubber kind of smell. I don't see any obvious melting or any smoke or anything. I turned down the gain on the amp and was driving for maybe 10 minutes, with the volume relatively low and the amp powered off. I checked the fuses and they were blown. What do you think is causing this? Should i "rebridge" the amp? Is it normal for new speaker wire to stink? Thanks for your help!
well the fuses on the amp being blown has me guessig there is a short in the wiring somewhere and you were smelling the jacket burning..
It's weird to me that the only 2 things changed were replacing the speaker wire from amp to subs, and wiring each sub to a seperate channel instead of them being bridged. Everything else is untouched and i never had any problems before.
If the speaker is 4 ohm an u have the +:+ -:- u are dropping them to two ohms if u bridge them they will drop to 1 ohm most likely the voice coil is what is giving the burned smell take the speaker out an inside the box it should reek an what kind of amp are u using
They were bridged before and i never had an issue. I have a 4 channel amp for the 4 front speakers and a Rockford p5002 2 channel amp driving the subs.
he said a p500.2 which is 2ohm stable per channel that's how he said he wired it, so that's not it and 8ohms wouldn't hurt anything at this point without looking at it it's a guessing game
I don't really know what to do. I haven't replaced the fuses on the amp yet, but i guess i'll try putting it back to bridged and hope my car doesn't start on fire and/or i pass out from poisonous fumes.
Huh ? Well the same Sorta thing has been happening to me except I keep blowing a single 15" iCandy the only thing I could think of was that the amp was to strong but in ure case that can't be the issue like he said its a guessing game from here on .... Are u grounding the amp?
re wire man don't just add new fuses your going to really damage something there a safety not fail proof pull all the wire and look for cut jacketing make sure your subs are right google some diagrams and make sure they match your goal.
Honestly, i don't have the skills to pull all the wiring. A shop here in Albuquerque did it at a car dealership's expense, and all the power wiring is under the carpet.
abqsean
abqsean
Albuquerque, NM
J31Rob
