Review my 4th order build
  • 4
nathanprice
19
Alabama
Before I build my 4th order, can someone look at it and see if there is anything I need to change? Thanks in advance!
3:1 ratio:
3ft³ ported chamber
1ft³ sealed chamber
Double baffle
Subs are going to be reverse mounted so that I will be able to smell them.
Ports are 5"x5"x7" tuned to ~45hz
Looks good what are your plans for bracing? What subs and amp u gonna run
I am going to use a 1" dowel in each ported chamber, displacements have been calculated. I am going to run my current subs and amp until I save up for an upgrade.
I currently have 2 Kicker Comp 12" and a Skar LP-100.2
nice efficient little build. Dont think those comps will need a double baffle though unless you plan on upgrading subs in the future. Did you plot out the box resonance for the sealed portion or are you just tuning to 45 because of recommendations?
Haha, I don't think they do either, but yeah, i plan on upgrading them eventually.
Did you plot out the box resonance for the sealed portion?
Not sure what you mean, elaborate please?
each subwoofer will have different resonant frequencies in sealed boxes depending on the size of the sealed box. for 4th orders you need to adjust the sealed portion so that your resonance lies somewhere within 45hz to 50hz then you test your cabin gain and vehicle transfer function with an spl meter and then tune the port to that peak for max performance.
I have not done that, is it extremely important?
if you want max performance yes. If you just want a 4th order that works then go ahead but projected sound quality and spl will be a crapshoot.
Use winisd.
I have used WinISD and this is what i got. per speaker
both added together:
not sure if that is good or bad
It will be a bit peaky but the comps aren't really ideal 4th order subs so I wouldn't worry about it. Either make it so you can take that whole front face off, or just pull out the ports to adjust them. Playing around with port lengths and sizes helps a lot. Your best bet is to do some trial and error if you don't have the equipment to get the design 100% right the first time.
I expected to be adjusting the ports, so I am using threaded inserts to be able to remove and replace the face. I am using the kickers because a ran across them for a deal: 2 kicker 12" in a prefab ported box for $85.
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
916
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
896
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
nathanprice
nathanprice
Alabama
nathanprice
saints747
    May 7, 2024
saints747
    May 7, 2024
