Alex JB
Hi,
I'm sure this has been covered but I searched and couldn't find quite was I was looking for so...
I just posted a big rant over on the Ford F150 forum about my set up so far,
F150 post
and something I'd like to fix is having a high pass and low pass filter on the channels to my rear doors.
I had a set up many years ago on a Citroen where the rear pillar speakers were only 3" cones and struggled with any kind of bass.
Someone gave me a tip to get a resistor of a certain rating to put inline and it would work as a HPF to cut off all the bass.
I read up on wikepedia and got to ---
1/(2*Pi*R*C) r= resistance c = capacitance gives the frequency cuttof of 70% of the voltage.
Or I could just punch in the fequency required and a resistor like 1KOhm and find the capacitor you need into this calculator...
http://www.opamplabs.com/rfc.htm
so in theory, a 1uF capacitor in + line and a 150Ohm resistor across the + and - would give you about a 1000Hz HPF...
Anyone done this recently?
Or do I need to get myself to radio shack.
I plan to do this and use the LPF (already at 100Hz ish for the front door speakers) in my 5 channel amp to cut off the high end - voila... a mid bass driver from a standard speaker, hopefully that doesn't pop and crackle like it does when you feed it a full range signal.
I think I'm on the right track, but please correct me, plus if you did this, let me know the resistor Ohms you chose and what results you got.
I basically can't afford to change the standard speakers out right now and I have what I have as far as H/U, amp and sub so I'm trying to make the best out of some not so brilliant OEM speakers.
F150 post
