replacing fuse
You just need 1 fuse, the fuse should be rated for whatever size the wire is. Unless the amp does not have onboard fuses, then you would fuse it for whatever the amp recommends.
Second thought if the amp is 1800 rms and you already have 0g. Then You will need a bigger fuse more like 200amps minimum or it's either going to pop or slowly melt.
kirby mane
kirby mane
Tuscaloosa,Al
kirby mane
Mike Mccabe
