Replacing Amps, Alpines...
ninjatek
Ninja Member
I want to replace the amp I have now
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3730
-4-channel car amplifier
-70 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
-200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
-2-, 3-, or 4-channel output
-variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
-tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
-subsonic filter (15 Hz, 24 dB/octave for channels 3 & 4)
-MOSFET power supply
-CEA-2006 compliant
-STAR Topology (minimizes internal noise and prevents ground interference)
-speaker- and preamp-level inputs
-preamp outputs
-gold-plated screw terminals
-fuse rating: 25A x 2
-8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
13-1/4"W x 2-3/8"H x 9-9/16"D
With this better Alpine
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4737
-RMS Continuous Power (14.4V, 20-20k Hz)
-150 Watts x 2 @ 4 Ohm
-150 Watts x 2 @ 2 Ohm
-300 Watts x 1 Bridged into 4 Ohm
-S/N Ratio : 100dBA
-CEA2006 S/N Ratio : 78dBA
-Input Impedance : 10k ohms
-Frequency Response (+0, -1dB) : 20 - 20k Hz
-Crossover Frequency (variable, LPF/HPF/OFF selectable)
-1/2 ch : 30 - 400 Hz (-12dB/oct)
-Input Sensitivity : 0.2 - 4.0V
-Dimensions : 10-1/8" x 2-7/16" x 7-9/16" (WHD)
-Class-D 1/2 Channel Operation
-MOS-FET Power Supply
-MOSFET Final Outputs
-Auto Over-Current Protection
-Unique Stacking Installation
-Quick Connect Speaker Terminal
-High Efficiency Digital Circuit Design
-Variable LP Crossover
-Thermal Management Processor
-Top Mounted Blue LED Power/Status Indicator
-Gold Plated RCA Input Connectors
-Adjustable Crossover (HP/LP/OFF)
-4-Layer Glass Epoxy PC Board
My issue is that I'm running the current amp bridged into stereo to get the 200x2 rms for my components, and the amp keeps overheating. I don't think its truly stable at 4ohm like they claim.
I'm hoping that the better Alpine Amp can push the same amount of power, but run cooler and cleaner...
Comments?
ninjatek
Ninja Member
ninjatek
Columbia, IL (St. Louis)
iowaaurora
