Replacement Line out converter/signal processor
kotec123
Flame
Currently i have a line out converter, and a orion phd300 line driver, to my kx2500.1, and am not really satisfied wt the sound.
What are my other options ..... I was thinking a PG Bass cube, or a cleansweep, and want to know what else is out there?
Only for my sub bass btw...
I want to spend no more then 200 ish
ty
What makes you "unhappy"?
Assuming everything is set up correctly; the only thing changing signal processing will "upgrade" is potentially the ability to defeat any factory EQ settings.....which may or may not be the problem.
Does the Factory headunit have a non-bypassable EQ that you want to correct?
i have a bose premium sound stock.....so i assume its un-bypassable
i need more sq and better response...its an old eq line driver so i think it might be shot./...sometimes it works well sometimes it doesnt....
i just think that and loc to a old orion cant be as good as other options....
The LC8 isn't going to do anything for defeating any built in equalization.
The Cleansweep would, but that and the RF 360.1 are a little overkill for simply wanting to run a subwoofer.
Ever thought about just switching to an aftermarket headunit ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yep and that thought was completely obviliated from the face of the earth since i have a factory amp, therfore i would have to re wire every and each speaker in the car to run the aftrmkt HU
i got a quote from a local shop....they said it would be about 500 said and done wt one of the alpine HU's that i liked
so yea id take a 250 dollar cleansweep bfr that
kotec123
Flame
kotec123
Chicago
kotec123
