removing door panel
How would you go aobut removing a door panel on a 1993 ford preb i basically got all the screws o ut now i just need to know how to take off the window roller uper thing off and basically how to take it off fplease the speaker is blown and needs fixing
the window roller has a "clip" shaped as a C that is benieth (spelling on that one? lol) the cowl of the crank. push the door panel in at the base of the crank, and use a flathead screwdriver (or a window crank removal tool - get them at pepboys iirc) and pop the clip off (DoNT LOOSE IT!) and then pull the crank off.
the rest of the door should come off easy. then when you go to put it back on, just put the pin back on the crank into the little slots it came out of, then put the crank in place, and give it a nice swift palm, and it will clip back on //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
its really easy actually //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hers a picture (the black C is what you need to remove) - basically push it off from the OPEN side and your all set.
heres a link to the crank removal tool (VERY ****in handy and costs like $8 at your local car stuff shop)
http://www.cardomain.com/item/SOU87600
almo181
Juggalo
almo181
Sasktoon (been there for 2 months)
johnecon2001
