remote wire?
if your using a factory h/u and loc, whats used for a remote turn on wire?
check voltage at your cig lighter, and see if it has 12v when the key is on and off...if no voltage when key off, then use that as your 12v switched source
Do not use power antenna
Tap the windshield wiper fuse in your fuse box, its has power in all of the key's on positions. But only if your using one or two amps, after that you seriously need a relay. But everything suggested above will work too.
do you have power antenna? how many amps you got?
negatory on all the above
why not the cig lighter if switched, i have used this plenty of times with no issues?
why not power antenna? Just wondering because I no longer have a powered antenna but am thinking about using the power wire thats still there. Just wondering whats your reasoning.
because when you run a cd or tape!? you won't have sub stage...power antenna only has 12v when am/fm is on
bigmandengo
bigmandengo
wisconsin
Worlddre
