remote wire
Are you sure it isn't the ground wire from your Deck? a power wire would turn it on, a ground wouldn't. But, if you grounded out the deck improperly, it would probably auto-turn off.
Is there two remote wires in your HUs wiring harness?
One with a white stripe and one without?
If so the one without the stripe is most likely meant for power antenna activation and only carries current in tuner mode.
If this is the case and you're using the one without the stripe n the insulation switch to the other one and see if it cures your problem
Ok, i hooked it up to the blue and white stripe one.....now it doesnt turn off but i still dont think that amp is getting a signal because it doesnt turn on....even if something is wrong somewhere else wouldnt the power light turn on on the amp just with the remote wire??
NO, The amp needs power and ground, plus the remote wire to turn on. All the remote wire does is send a small amount of power to the amp, i think it's around .30MA. It's pretty much just lets the amp know the Hu is on, So power on.
im having the same problem you are. my amp wont turn on.
people told me to jump the remote terminal by taking a peice of wire and touched the remote terminal to the battery terminal on the amp. it should turn on. if it does turn on when you jump it, turn off your key in your car and check if the amp is on or off. if it turned off then its your power wire or your inline fuse. i have to change my fuse out tomorrow and see if thats what it is. so far everyones been telling me that it is.
hope that helped you in some way. newbie to newbie. if im wrong, you cant blame me because i know nothing =)
Well my power wire is fine, i touched it against my tool box and i know for sure it is getting power. I will check the ground connection tomorrw to see if that is the problem.
cvass20
Cvass
cvass20
Vancouver
johnson
