Remote wire to Battery?
No, run the remote wire to the remote out on the back of the headunit. You can then install a switch on the remote wire to turn it on or off, but if you run it directly to the battery you will have problems because the amps will always be on, and you will kill your battery.
connect your remote wire to the blue wire with white stripe coming from your deck.....somewhere in line add a $3.00 toggle switch...get the one without the blingy lights so only two connections...tie it in line with your remote wire...one side to deck the other to amp...then you can switch the amp on and off FTW //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and then go get a loan and not pay it back
The car is an Impala, and theres no remote wire on the stock radio so i dont know what to wire the remote wire to.
you can wire it to an ignition controlled accessory spot that is currently not being used in your fuse box......you should probably fuse it tho
WINRAR.
nG
muskymatt913
muskymatt913
chicago
ntech14
