remote wire help...
▼)Ñ╩fZΣµ&
installed amp in and everything is right according to instructions etc
but the Remote wire doesn't really seem to be doing so good...
1st car start = amp doesnt turn on
2nd car start= amp turns on all good and all
3rd car start = amp doesnt turn on
4th car start= amp turns on, but the volume on the deck goes to 0 by itself....
then again later it went up by itself... how do u install his wire? just strip it and put it in? or is there special connectors i should be using?
or any other ways to just fix this whole thing i am running a kicker 750.1
kinda long : \
vehicle year make and model and where did you connect the remote wire to after you hooked it to the amp
1996 Ford explorer, Headunit is a Pioneer deh 5900
i wired the Remote wire from the amp to the back of the headunit on the same side as RCA's and i just stripped it about 1 inch folded it over n stuck it in. and when moving it around shit started to act wierd
▼)Ñ╩fZΣµ&
▼)Ñ╩fZΣµ&
reno
damonhargroves
