Remote wire below 10V
ox45
Hello forum!
I'm trying to install a system for my brother, but ran into a problem. I hooked everything up and the HU powers up and plays fine, but the amp won't turn on. The 12+/- are both fine, but the remote line is only reading about 7.5V. I tried testing directly from the HU side of the rem line and same thing. All the voltages coming into the HU are correct. I also tried testing the power antenna line and it reports the same voltage at about 7.5V. Is it just a defective HU or is there something else weird going on.
The HU is a Jensen VM9312.
Thank you in advance!
Without actually being there to do some tests on the HU I would think that the HU just doesn't have the output to support your aftermarket amp, or the HU has a defect in it's output power. I would try exchanging it if it is new and see what you get. You may also have a defective wiring harness. Check power coming in to the HU from the factory harness, if it is over 10Vrms then I would guess the HU
Thanks for the quick replies!
I tested the output right at the harness and it reads just fine at around 14V. It's brand new so I just have to find a store around that has another in stock. Unfortunately it's a touchscreen LCD in his price range so I doubt I can talk him into switching up for something a little better. With the Jensen being less quality would I be better off doing the relay method anyways?
I would. I don't like to product bash but the Jenson brand is just not really up to par with many other brands that are in the same price range. I would do what you can to convince him to upgrade to another brand but if you can't I would just run a relay to the amps.
ox45
ox45
Buffao, NY
spin dB
Mike Mccabe
