remote turn on help
You are giving out false information here, guy...
If you hook it up to the power antenna, it will only turn on when the radio is in use.
Do you have an aftermarket head unit for the vehicle? If so, then the wire is more than likely solid blue, if there is two blue wires (one with a white stripe) then it is the one with the stripe.
That's odd, because mine is hooked up to the power antenna and my amp is powered whenever my head unit is powered...
By the way, I know you are expirienced, and you don't like taking criticism from a those of a lower post count, but come on... Look at the first post here. "im about to install an amplifier in my sister's car which will still have the stock hu."
what red wire? and where?
Not sure exactly what he is telling you, but the ignition wire will do fine. Any wire that has a constant voltage when the vehicle is turned on will work, get a mulimeter and go to town if you need to //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
behind your stock deck should be your oem harness. generally black is ground, red is ignition, yellow is constant. so... whenever you turn on your car your amps will turn on. is this okay for you?
Unfortunately, waaaaay wrong.
First, the wire colors your are listing are the aftermarket standard. They are not followed by ANY vehicle manufacturer that I am aware of. In a GM, you'd usually find the accessory wire as yellow (but there's more than one yellow in the harness) and the constant power wire as orange. The ground would usually be black, true; but in other makes of vehicles it might be black/green, or red, or brown, or not present at all. Red is not used behind the radio in a GM.
Second, it's a 2005 Cavalier, so it's a data bus radio. There is no accessory wire at all behind the factory head unit. There's also no Cavaliers with stock power antennas or factory amps, so there is no wire behind the head unit that will function as a remote turn-on.
To the original poster: there are two options.
1. Use a test light or multimeter to find a fuse in the vehicle fuse box that loses power when the key is switched off, and tap the remote wire onto the fuse blade. Be sure to put your own fuse onto the remote wire (a 1 amp fuse is fine).
2. Tap into the heavy brown wire under the steering column in the harness that runs from the key switch. The wires aren't all that easy to get to in a Cavalier, but it can be done if you take apart the steering column shroud. The brown wire is the key-switched accessory output. Again, you need to put your own fuse on the your remote turn-on wire.
neumann
neumann
michigan
reneeb7363
ThxOne
    May 13, 2026
