remote start problems
2dmnloud
i just recently bought the autopage850lcd alarm with remote start....i can't figure out why the remote start not working i have gone through the tach learning process but when i get to the voltage checking process nothing happens i hit the button my door locks lock and lights flash and thats about it....its going in a 98 blazer it sounds like one of my ignition wires are wrong does anybody know if i have to have a 3 ignition wire i'm so lost i have checked all the voltages with key on and off and everything checks out....pleaseeeeeeee help
You should not need both voltage sense and tach. I would just hook up tach to the no like color of the fuel injector wire. also if u have a hood pine switch make sure that is all good and not letting it start. I am used to vipers so i am hoping some of this info will be usefull. If it is learning the tach but still not starting there is a nutral saftey shutdown wire {Viper once again } make sure that wire is grounded.
12volts red + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue + brown plug at BCM
Notes: The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side.
Power Unlock white + brown plug at BCM
Lock Motor gray 5wi driver kick panel
Unlock Motor tan 5wi driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Notes: This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
Hazards
Turn Signal(L)
Turn Signal®
Reverse Light
Door Trigger - BCM
Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, and dk. blue/white for the rear doors and rear hatch located in pin B11 of the lt. blue plug, must diode isolate these wires.
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black - lt. blue plug at BCM
Hood Pin
Trunk/Hatch Release black - purple plug at BCM
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white ac PCM
Notes: The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.
Wait to start N/A
Brake Wire white + steering column
Parking Brake
Horn Trigger black - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes
Hope that helps too a little bit more.
thanks man but thats the exact wires i tap into...those direct electronics fax sure are helpfull any more ideas
i checked the neutral sfety switch to make sure it was not seeing 12volts at all time the only time it sees 12v is when the pedal is pressed so i know thats ok
i have tried that i have even turned the key to where my acc comes on and hit the button and nothing.....i think i don't have the right ignition wire's....because when i hit the button my door locks lock my lights flash and thats about it i have a picture of a ignition key....any other ideas
well if u are 100% sure all the wires are correct, and that everything is hooked up right it could be a bad unit. Its rare but i have had a few vipers do that to me
Yes he does have passlock two, But when he put the key in the ignition and it still did not remote start then it is something wrong with the remote starter/install, because the PCM would have seen the code on the key and started up.
2dmnloud
2dmnloud
Mississippi
toxicwaste8504
NorthFramingham
    Jun 30, 2026
