remote gain question???
rregl
21
Pa
Ok,, I'm a noob.. I have a question about remote gains.. when you plug them in do they replace the gain level control on the amp completely or will they only alllow adjustment up to the maximum you selected on the amp?
amps are 100.4 and 1500d sundowns.. thanks
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
508
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
rregl
rregl
Pa
rregl
SPLBassJunkie
    May 21, 2024
    May 20, 2024
