remote bass?
is the remote bass beaically the same thing as bass boost? yes/no
or
1. is boots not the best..
and 2. the remote bass just controls if its bass on or off basically? yes/no
Bass boost you need to set wisely.
It could make your subs clip.
The remote is most likely for the Level.
Remotes were made so you can adjust the bass level for each song from sitting in your driver seat, not having to go back and adjust the amp.
Bass boost you need to set wisely.It could make your subs clip.
ok well.... u kinda just said the one on the amp would be not to ess with.. kk got that
but then u say the remote would be so u wouldnt have to GO back there and adjust it....
but why would i adjust it if it screws my gain and settings up?...
whatever im hoping its just to turn bass on or off in general basically, NOT bass boost that jacks stuff up
Say your listening to Kanye West - Stronger.
The song sounds HORRIBLE with lots of bass.
You could just use the remote and turn the bass down to a reasonable level.
Then if your listening to Lil Jon - Da Blow
The song sounds GREAT with lots of bass.
Then you turn the bass up. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
all the remote does is alow you to raise the level of your bass boost by 1% so in a hole the bass boost knob itself is not that bad( as long as you have the bass boost all the way down at the amp) eather way you look at it bass boost is a shitty thing man if you need to use it you just need a bigger amp or to strap two, sorry to say it.
▼)Ñ╩fZΣµ&
▼)Ñ╩fZΣµ&
reno
rumple4skin
