Relay for remote turn on?
bradl79
i am trying to understand how to set up a relay, so do i have to run an new wire from my pos battery terminal and run to the relay, i already have one going to my amp. then i need to ground the relay with another wire to another ground spot, then connect the remote turn on wire to the relay then i can run 2 or more remote turn on wires to the relay? am i understanding this correctly?
anyone have a good guide, thank you.
86 to remote from radio - 87 to 12v constant - 85 to ground - 30 to remote input from amps, EQs, XOs etc.
You can get the 12V from the amp power terminal. But treat it as if you were attaching to a battery and put a small fuse (2 amps maybe) close to the amp terminal.
bradl79
bradl79
NLR
maylar
vegang
vegang
