Reducers
Reducers are a great way to fit 0 gauge wire in 4 gauge in/outs. They give you a really tight, all around fit for the wire; also in my opinion.....it doesnt reduce your power flow as much as people seem to worry about... its really not like having 4 gauge wire at one point, because the reducer acts as a terminal, not as more wire length.
lol. no.
it is like having 4gauge at 1 point. but that doesn't mean it makes a difference. every gauge of wire has a limit, and if that limit is not reached, you see no negative effects. hence why i can use 0 gauge to a distribution block, and 8" runs out to my amps, and still have 0 voltage drop across the points.
and there is no "acts as a terminal, not as more wire length"....it acts like a smaller connection point and thats it. same shit as if you shaved some wire off the 0g to get it to fit into the 4 gauge terminal.
right now i have 4 gauge terminals with the reducers if it would help i was gonna get terminals that accpet 0 gauge...but im just gonna keep the reducers.
here is wha ti have
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140167631094
nvm, youll be fine. i still dont see what you're going to be doing with teminals that accept 0 gauge, but if you're just talking about trying to run power from a 1/0 run to an amp with 4 gauge inputs, you are fine with what you have now.
ok let me explain....right now i have a battery terminal that only accpets 4 gauge....i bought a reducer to run 0 gauge into my 4 gauge terminal.....i then was wondering if it would make a difference if i went out and bought a terminal that accepts 0 gauge if i would see any difference out of the 0 gauge.....meaning i would get rid of the reducers
will see no difference. just less money in your pocket.
connersdad19
connersdad19
Logan, Ohio (43138)
ultimate157
michigan born
    May 14, 2026
michigan born
    May 14, 2026
