Originally posted by nswartley but if your alternator is too weak to power the batteries then its close to pointless to put yet another thing that needs to be charged in your electrical system
Originally posted by dave_3148 rewibding your alts not gonna do a **** thing for your battery life when you play your system with your car off, get a better battery
You are both only partially correct...
nswartley, you are correct, in the way that you worded your sentence.
But are you accounting for insufficient wiring?
Consider drinking soda at a restaurant... you have the choice of a coffee stirrer, or a straw. You can **** with the same force (alternator capacity), and you will get more soda (voltage) in your mouth (at the amps) due to less resistance (ditto... burning up current in the wire, resulting in a voltage drop) in the straw compared to the coffee stirrer.
I'd rather use the straw... and look, I just might NOT need to **** harder to get sufficient soda in my mouth!
Likewise, you might
not need to replace the alternator to maintain sufficient voltage levels, and current-draw capacities.
It's a matter of
diagnosing what the appropriate bottleneck is! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And
dave_3148...
You are correct that a bigger battery will help with engine-off play time...
But realistically, what's the threshhold between having a system that's big enough to drain a stock battery into pulverization (almost literally.. warped plates, after all)... and having a system that's big enough to risk draining literally ANY battery that you can fit in there? Large current draw is large current draw...
I seriously NEVER listen to my system with my car off... IMO it's just asking for trouble. The car is your transportation... you got somewhere in it, why risk showing it off somewhere and getting stuck there? Wouldn't it be ironic if someone that you were showing it off too didn't have the most moral of intents.. you had to leave your car.. and your stuff got jacked? Bad bad bad... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
