Reconeing Question
x1le
I'm certified.
So I'm ripping apart my 15" Fi Q getting it ready to attempt my first recone. I finished removing the glue/gasket from the basket and went to remove the spider material but am having some difficulty with it. Wondering if there is any trick to this, or should I just grind it all down with a dremel?
thanks in advance.
I used to use a straight die grinder with a sanding cookie but it has been may years since I ever reconed anything but an IDmax. If you can sand it with a dremel it might take a while but if a razor is not working you gotta do what you gotta do
Yeah, I was able to sand down the gasket on the basket no problem, but the spider is obviously much more rigid and is a lot tougher //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
x1le
I'm certified.
x1le
Mass
x1le
