Reconed 18" re sx for headunit. Socal
supermaxx123
I.E.
Bought it off here right after it was re coned. Dual 2 coils. Never used it. Only tested for about 10min.
Looking for
-active/time alingment/eq
-ipod
-bluetooth
-red backlights to match car if possible
Im located in so cal area 92868, local trade.
if its a sweet headunit i can add cash.
Kenwood x993, 3 way capable, time alignment, all that good stuff, iPod control, by hand or by the unit, which is VERY easy to use by the way, has Bluetooth for your phone, and it has about 10 different colors you can choose from, including red, 3 4v preouts, it's minty.. I just don't need it I'm about to order my 80prs.
Let me know if you're interested
392
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
986
supermaxx123
supermaxx123
I.E.
Spooney
    May 12, 2024
Brendon Jenness
    May 11, 2024
