1. Product:
parts to rebuild subs, a custom D1 12" sub, other randomness
I have 2 other for sale threads that I am using pics from
2. Specs:
2 MA Audio HK motors a 12 and a 15, 2.9 ID 3.3 OD, standard bolt pattern SOLD
2 15" 12 spoke baskets, standard bolt pattern
2 2-layer round wound voice coils brand new D.6 ohm, 3" ID 3.25" OD 3.25" WW 4.125" former
MT D1 8 layer FW voice coil, 3" ID 3.375" OD 2" ww 4.6" former
D1 4 layer FW, 3" ID 3.25" OD 2.25" ww 4.125" former
2 carbon fiber full cone dustcap, made for 12's
1 15" full cone PBX dustcap
2 hard spider with quad sewn leads, 8", 3" voice coil
custom 12"
-Hifonics goliath motor
-3" 4 layer FW D1 coil
-12 spoke basket
-rubber surround
-single hard progressive PSI spider
-5" plain dustcap
-chrome push terminals
-1200 rms
B.A.S.S. 15" sub
-Recommended Power: 40 Watts to 900 Watts
-2" Parabolic RFL Voice Coil
-60 oz. Magnet
-Oversized Rubber Surround
-4 Ohm Impedance
-Poly Zirconium Cone
-Efficiency / Sensitivity 96dB @ 1 Watt / 1 Meter
-Polyimide Voice Coil Former
-Flat Progressive Roll Spider
-Vented and Extended Pole Piece
-Low Carbon Top and Bottom Plate
-Weather Resistant Design
-Approved for Car Audio and Marine Use
15" sub box 3.5 cubes tuned to 35 hz, bare wood
custom built, solid and loud
Bazooka triangle sub and borted box
-"10" triangle RX-T1 subwoofer loaded in ported triangular enclosure
-efficient enclosure designed for mounting in your trunk, hatch or behind the seat of your pickup truck
-4-ohm impedance
-frequency response 20-1,000 Hz
-power handling 200 watts RMS/450 watts peak
-sensitivity 104 dB
-17-7/8"W x 15-1/2"H x 18-1/8"D"
Profile california 400msx mono amp
-Width 11.7 in
-Depth 9.8 in
-Height 2.2 in
-Signal-To-Noise Ratio 105 dB
-Max Output Power / Channel Qty 400 Watts x 1
-Continuous Power / Channel Qty 200 Watts x 1
-Amplifier Output 1-channel
-High Level Inputs Yes
-Input Signal Voltage 0.2 - 8V
-Crossover Active crossover
-Crossover Slope 12 dB/octave
-Low Pass Frequencies 40 - 130 Hz
-Bass Boost Frequency 45 Hz
-Bass Boost Gain 0 to +12dB
-Output Power / Total 600 Watt
-Distortion Factor 0.07%
-Amplifier Output Details 200 Watt - 4 Ohm - 1 channel(s) ¦ 300 Watt - 2 Ohm - 1 channel(s)
-Gold plated connectors, thermal protection, short circuit protection, DC offset protection
3. Description/Condition:
2 MA Audio HK motors used SOLD
2 15" 12 spoke baskets, used and uncleaned, could use new paint
2 D.6 voice coils brand new
MT D1 voice coil, 3" used but good
D1, 3" used but good
2 carbon fiber 12" full cone dustcap, new
1 15" full cone PBX dustcap, new
2 hard spider with quad sewn leads, new
Brand new, havnt even cut out the mounting holes in the surround yet
so excess glue around the surround and dustcap
basically everything thing is used but in good condition
4. What you are looking for: :
Looking for a competition podum that I can put my CD player in and maybe some speakers, nothing fancy
Soundstream amps
XS Power battery
maybe others
pics
The cone and gaskets ARE GONE
the push terminals ARE GONE
2. Specs:
custom 12"
-12 spoke basket
-rubber surround
-5" plain dustcap
-1200 rms
B.A.S.S. 15" sub
-60 oz. Magnet
-4 Ohm Impedance
-4-ohm impedance
-sensitivity 104 dB
-Width 11.7 in
-Depth 9.8 in
-Height 2.2 in
Soundstream amps
XS Power battery
maybe others
pics
