recommended amp install kit for hertz HDP 4
  • 2
kkjjjmccann
21
maryland
looking to buy a good quality amp install kit for my hertz HDP 4 amp.
going in a double cab tacoma-will be installing under seat.
also what do you guys recommend for speaker wire?
like to buy in a kit unless its better to buy separate
thanks for your help
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
190
389
kkjjjmccann
kkjjjmccann
maryland
kkjjjmccann
